[Qgis-developer] Raster providers
Marco Hugentobler marco.hugentobler at sourcepole.ch
Tue Mar 1 03:27:41 EST 2011
Hi Radim, Tim
> That being the case, I would suggest we poll Marco and other devs to
> see if it can move into trunk so that it can be more broadly tested
I briefly tested the raster provider branch today and it works great. The
performance seems to be fast now even with reprojection turned on. The only
thing with my test rasters that didn't work was the 'zoom to best resolution'
function. However, this is a detail and I'm in favor of merging the branch to
trunk soon and fixing the minor issues there.
Regards,
Marco
Am Montag, 28. Februar 2011, um 10.59:21 schrieb Tim Sutton:
> Hi
> On Mon, Feb 28, 2011 at 10:01 AM, Radim Blazek <radim.blazek at gmail.com>
wrote:
> > On Sun, Feb 27, 2011 at 9:54 PM, Tim Sutton <lists at linfiniti.com> wrote:
> >> Do you have anything else left on your todo list before you can merge to
> >> trunk?
> > It looks like this:
> > qgsrasterprojector.* qgsrasterdataprovider.* raster/qgsrasterlayer.* : 60
> > TODOs qgsgdalprovider.*: 11 TODOs
> > qgsgrassrasterprovider.*: 8 TODOs
> > qgswmsprovider.*: 53 TODOs
> > But all those TODOs are not really problem, IIRC, before the merge I have
> > to add only fall back to precise reprojection if approximation fails
> > (easy) and code cleanup.
> > The problem with data reloading on update (G. Manghi reported) I would
> > like to solve in trunk
> > because it may need QgsLayer and renderer modifications.
> > Then, there are some places, usually constants which have
> > to be checked better (e.g. max error, in reprojection, minimum source
> > resolution etc.)
> > That can still be done in trunk, I think.
> before the release - I don't think it will be good to merge it at the
> last minute before the release for this reason.
> > BTW: The approximate reprojection could may be used also for vectors?
> Hmm interesting. Is there a summary of the logic you have used to do
> this somewhere?
> Regards
> Tim
> > Radim
> >> +1 from me to merge when you are ready
> >> I would like to make some cleanups to the raster properties dialog
> >> after you are done...hopefully I can do the ui clean upsin time for
> >> 1.7....
> >> Regards
> >> Tim
> >> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> >> Please do not email me off-list with technical
> >> support questions. Using the lists will gain
> >> more exposure for your issues and the knowledge
> >> surrounding your issue will be shared with all.
> >> Visit http://linfiniti.com to find out about:
> >>  * QGIS programming and support services
> >>  * Mapserver and PostGIS based hosting plans
> >>  * FOSS Consulting Services
> >> Skype: timlinux
> >> Irc: timlinux on #qgis at freenode.net
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
