[Qgis-developer] macosx dialog issues
John C. Tull jctull at gmail.com
Sat Mar 5 13:40:54 EST 2011
Hi Carson,
I am working through the tools to see where there might be problems on my end, but a list of the specific ones that gave him trouble would be helpful.
The only problem I had was with Merge Shapefiles. If I tick the 'Select by layers in the folder', I cannot choose a folder in the dialog. The Ok button never becomes available when trying to select a folder. I can select a shapefile and the OK button is available. I might be misunderstanding what this option is intended to do. When turning it off, I can select a folder, but the tool crashed qgis. This was because my folder had mixed geometry types. See output below. I suppose this crash should be avoided somehow.
One random thought arose as I tested the tools. Why is the random select tool limited to 30 features?
Also, I have qt-4.7.1 and was using a current trunk build.
Cheers,
John
/Applications/QGIS.app/Contents/MacOS/QGIS
Python support ENABLED :-)
Loaded : Create custom db queries (package: customdbquery)
Loaded : Freehand editing (package: freehandEditing)
Loaded : Google Layers (package: GoogleLayers)
Loaded : Load Them All (package: loadthemall)
Loaded : manageR (package: manageR)
/Users/jctull/.qgis/python/plugins/openlayers/openlayers_plugin.py:150: DeprecationWarning: QgsCoordinateReferenceSystem.createFromEpsg() is deprecated
 if not self.__coordRSGoogle.createFromEpsg(idEpsgRSGoogle):
Loaded : OpenLayers Plugin (package: openlayers)
Warning: QGraphicsScene::removeItem: cannot remove 0-item
Loaded : Openlayers Overview (package: openlayersov)
Loaded : PgQuery for QGIS (package: pgquery_plugin)
Loaded : PostGIS manager (package: postgis_manager)
Loaded : QGIS File Browser (package: QGISFileBrowser)
Loaded : RT Sql Layer (package: rt_sql_layer)
Loaded : Save As SLD (package: saveassld)
/Library/Frameworks/GDAL.framework/Versions/1.8/Python/site-packages/osgeo/gdal.py:80: DeprecationWarning: gdal.py was placed in a namespace, it is now available as osgeo.gdal
 DeprecationWarning)
Loaded : DEM relief shader (package: shadedrelief)
Loaded : Statist (package: statist)
Loaded : Table Manager (package: tablemanager)
Loaded : Visibility Analysis (package: vap)
Loaded : Zip Layers (package: ziplayers)
/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py:283: DeprecationWarning: the sets module is deprecated
 mod = _builtin_import(name, globals, locals, fromlist, level)
Loaded : fTools (package: fTools)
Loaded : GdalTools (package: GdalTools)
Warning: QHttp: empty path requested is invalid -- using '/'
Loaded : Plugin Installer (package: plugin_installer)
2011-03-05 10:09:10.969 QGIS[94799:a583] *** __NSAutoreleaseNoPool(): Object 0x116ec1530 of class NSConcreteMapTable autoreleased with no pool in place - just leaking
ERROR 1: Attempt to write non-polygon (LINESTRING) geometry to POLYGON type shapefile.
More than 1000 errors or warnings have been reported. No more will be reported from now.
Warning: OGR[3] error 4: Unable to open /Users/jctull/Desktop/temp/test.shx or /Users/jctull/Desktop/temp/test.SHX.
Critical: Data source is invalid
Critical: Unable to open /Users/jctull/Desktop/temp/test.shx or /Users/jctull/Desktop/temp/test.SHX.
Warning: QObject::setParent: Cannot set parent, new parent is in a different thread
Warning: QPixmap: It is not safe to use pixmaps outside the GUI thread
Segmentation fault
On Mar 5, 2011, at 3:37 AM, Carson Farmer wrote:
> Hello Devs,
> A user (Dr. José Carlos Guerrero) has contacted me recently with a
> problem that appears to stem from Qt dialogs on MacOS:
> José is unable to specify output files from several of the fTools
> tools where a save dialog should be popping up.
> His install came from here: http://www.kyngchaos.com/software/qgis and
> the relevant particulars are here:
> MACOSX 10.6.6
> QGIS 1.6
> ftools: 0.6.1
> Any thoughts?
> Carson J. Q. Farmer
> ISSP Doctoral Fellow
> National Centre for Geocomputation
> National University of Ireland, Maynooth,
> http://www.carsonfarmer.com/
> Qgis-developer mailing list
