[Qgis-developer] symbol levels in rule-based rendering
Borys Jurgiel lists at borysjurgiel.pl
Sat Mar 5 15:36:19 EST 2011
> The only downside I see here is that the symbols which are going to be
> use the effect of overpainting - like the roads with outlines - have
> to be split to bottom and top layer and applied in two different
> styles. But I think that is a relatively low price given the
> advantages. Finally, there are not that many symbols that would need
> this effect.
I don't find it as a usability problem. The present symbology is unusable
unless you understand symbol levels, and the "sld" approach is as
simple/complicated as the present one. And is of course more flexible.
+1 for compatiblity with the way SLD chose.
