[Qgis-developer] Compile QGIS r15395 - ui_qgisapp.h not found
Luiz Motta motta.luiz at gmail.com
Wed Mar 9 12:28:50 EST 2011
Thank´s  Devs,
I had some  files did not recognized by SVN. They are files of
"spatial query plugin"  when i worked them.
I removed these files and did download again from SVN.
At now, we can see "the on the fly"  Raster with google's image by
Openlayers Plugin:
http://www.flickr.com/photos/60423637@N07/5512018785/in/set-72157626231166512/
Regards,
Luiz
2011/3/9 Martin Dobias <wonder.sk at gmail.com>:
> On Wed, Mar 9, 2011 at 2:58 AM, Luiz Motta <motta.luiz at gmail.com> wrote:
>> Devs,
>> I tried compile QGIS r15395, in ubuntu 10.10,  and get this message:
>> [ 35%] Building CXX object src/app/CMakeFiles/qgis.dir/main.cpp.o
>> In file included from /home/lmotta/dev/cpp/qgis/src/app/main.cpp:66:
>> /home/lmotta/dev/cpp/qgis/src/app/qgisapp.h:83: fatal error:
>> ui_qgisapp.h: Arquivo ou diretório não encontrado
>> compilation terminated.
>> make[2]: ** [src/app/CMakeFiles/qgis.dir/main.cpp.o] Erro 1
>> make[1]: ** [src/app/CMakeFiles/qgis.dir/all] Erro 2
>> make: ** [all] Erro 2
>> I followed the qgis-1.6.0_coding-compilation_guide_en.pdf (using ccmake).
> Try to run cmake and then compile again.
> Martin
