[Qgis-developer] Raster providers
Radim Blazek radim.blazek at gmail.com
Wed Mar 9 16:47:12 EST 2011
The reason is, that GDALCreateGenImgProjTransformer() does not accept
source data sources which are not georeferenced. As an ugly
workaround, I set the first item in GeoTransform (x offset) to
DBL_MIN. In theory it can cause a shift in georeferencing. I don't
believe however that it could be really a problem. The shift is
2.22507e-308.
Se also cc from gdal list.
Radim
On Wed, Mar 9, 2011 at 9:53 AM, Werner Macho <werner.macho at gmail.com> wrote:
> Hi all!
> I  tried to load a simple jpg (without any projection information) into
> QGIS just to test ..
> It unfortunately leads to a segfault ..
> Then i thought to georeference the file first ... and opened the
> georeferencer plugin .. but it seems the georeferencer plugin uses the
> same mechanism to load the jpg as qgis itself .. so nothing showed up
> and I were not able to georeference the raster file ..
> It seems that there whould be some defaults for rasterfiles without any
> projection information. Otherwise it is not possible to create
> georeferenced files any more..
> Anyone can confirm this?
> best regards
> Werner
> Qgis-developer mailing list
