[Qgis-developer] Raster providers
Manuel Massing m.massing at warped-space.de
Mon Mar 14 16:46:12 EDT 2011
> the problem seem to be incorrect / inconsistent
> handling of geotransforms with positive y-axis
> scale. I have the feeling that at some place the
> raster extent calculation is performed using
> a negative y-axis (probably because the CRS is
> not valid), but some other routines from
> the gdal raster provider use the directions given by the
> geotransform.
this seemed indeed to be the case, I have commited a
fix in r15481 (just adjusting the geotransform to
have negative y axis if no geotransform is available).
(should fix #3596, but please test)
bye,
	Manuel
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110314/a50ea3a3/attachment.html
