[Qgis-developer] Not able to save a layer as a tab file
Luiz Motta
motta.luiz at gmail.com
Wed Mar 16 08:39:05 EDT 2011
Milena,
I confirm yours comment about write file in format TAB.
I read the source and i believe has a procedure inconsistent in file:
http://trac.osgeo.org/qgis/browser/trunk/qgis/src/core/qgsvectorfilewriter.cpp
I would like that Tim could see the method
QgsVectorFileWriter::driverMetadata(Line 895):
else if ( driverName.startsWith( "MapInfo File" ) )
longName = "Mapinfo File";
trLongName = QObject::tr( "Mapinfo File" );
glob = "*.mif *.tab";
ext = "mif" ;
This method set the ext(extension) equal "mif".
In method QgsVectorFileWriter::QgsVectorFileWriter in line 134:
if ( QgsVectorFileWriter::driverMetadata( driverName, longName,
trLongName, glob, ext ) )
if ( !vectorFileName.endsWith( "." + ext, Qt::CaseInsensitive ) )
vectorFileName += "." + ext;
We can see that extension is "mif" (always), then, the output format
is the MIF.
You can open the ticket about this.
Regards,
Luiz
I read the
2011/3/16 Milena Nowotarska <do.milenki at gmail.com>:
> Hi,
> In QGIS we were able to save a vector layer as MapInfo tab. In r15470 (and
> before) we are able to save as MapInfo mif only.
> If you try to force the file extension by inserting "name.tab" you will get
> "name.tab.mif" in the end anyway.
> Using win7 and osgeo4w.
> Milena
> Milena Nowotarska
> http://wiki.osgeo.org/wiki/Milena_Nowotarska
> http://quantum-gis.pl/ || http://grass-gis.pl/
> Qgis-developer mailing list
