Re: [Qgis-developer] Advice on VRP plugin development
Sergey Yakushev yakushevs at list.ru
Thu Mar 17 01:56:34 EDT 2011
Unfortunately. At this moment you can not use the code Road Graph plugin in Python. I will do it later (on QGIS 1.8).
Wed, 16 Mar 2011 10:43:03 -0700 (PDT) письмо от cremat0rio <davidsantospinheiro at gmail.com>:
> Hi all!
> I would like to create a QGis plugin to solve the Vehicle Routing Problem
> (VRP) using Evolutionary Computation techniques (Genetic Algorithms and
> stuff like that).
> I have some initial questions, so if someone can help-me, I'll appreciate it
> very much.
> 1. What programming language should i use? I know that there's the
> possibility to create plugins in Python or C++, but the Python Plugin
> Installer, as the name states, can only be used for python plugins.
> The problem of using python is about speed/performance, because VRP is a
> very hard problem, especially when is solved using Evolutionary Computation
> techniques.
> There seems that i have 3 options:
> a) Do all the work in python, using some libraries to speed up the thing
> (like scipy).
> b) Build the interface in python and the core library in C++. I don't know
> if python and C++ can integrate well. I don't know either if this can be
> done, because C++ has to be compiled for the client machine (that can be
> windows, linux, ...)
> c) Build the interface in python and the core library in java. I don't know
> if python and java can integrate well too, but java can run in almost every
> platform and is fast.
> 2. For the plugin to work, i need to find the shortest path between any two
> points on a POINT layer, using a LINESTRING layer for the road network. In
> the new QGis development version there's a plugin/tool named "shortest
> path". Can i use it to calculate this distances from a python plugin?
> Any help or advice is very appreciated.
> David Pinheiro
> http://osgeo-org.1803224.n2.nabble.com/Advice-on-VRP-plugin-development-tp6178156p6178156.html
> Sent from the qgis-developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
С уважением Якушев Сергей yakushevs at list.ru
