[Qgis-developer] Compiling Linux/ubuntu 64 bits
Tim Sutton lists at linfiniti.com
Sat Mar 19 03:49:50 EDT 2011
Luiz
Try to remove any existing install of QGIS first - if you have an
older install of QGIS alongside a development install, it can cause
such errors.
Regards
Tim
On Fri, Mar 18, 2011 at 9:48 PM, Mayeul Kauffmann
<mayeul.kauffmann at free.fr> wrote:
> Hi,
> I compiled QGIS without problem earlier this week without any problem on
> the exact same architecture (except the window manager):
> KUbuntu 10.10 64 bits, Python 2.6.6 (r266:84292, Sep 15 2010, 16:22:56).
> Could you share the exact sequence of commands you are doing? It might
> help.
> Mayeul
> Le jeudi 17 mars 2011 à 20:25 -0300, Luiz Motta a écrit :
>> Hi Devs,
>> At now, i compile the QGIS R15530, Linux/Ubuntu 10.10 64 bits
>> I can't use plugins  python, i receive this error:
>> Couldn't load PyQGIS.
>> Python support will be disabled.
>> Traceback (most recent call last):
>>   File "", line 1, in
>> ImportError: /usr/local/share/qgis/python/qgis/core.so: undefined
>> symbol: _ZN14QgsMapRenderer17setDestinationSrsERK28QgsCoordinateReferenceSystem
>> Python version:
>> 2.6.6 (r266:84292, Sep 15 2010, 16:41:53)
>> [GCC 4.4.5]
>> QGIS version:
>> 1.7.0-Trunk 'Trunk', 15530
>> Python path:
>> ['/usr/local/share/qgis/python', '/home/luiz/.qgis/python',
>> '/home/luiz/.qgis/python/plugins',
>> '/usr/local/share/qgis/python/plugins', '/usr/lib/python2.6',
>> '/usr/lib/python2.6/plat-linux2', '/usr/lib/python2.6/lib-tk',
>> '/usr/lib/python2.6/lib-old', '/usr/lib/python2.6/lib-dynload',
>> '/usr/local/lib/python2.6/dist-packages',
>> '/usr/lib/python2.6/dist-packages',
>> '/usr/lib/python2.6/dist-packages/PIL',
>> '/usr/lib/python2.6/dist-packages/gst-0.10',
>> '/usr/lib/pymodules/python2.6',
>> '/usr/lib/python2.6/dist-packages/gtk-2.0',
>> '/usr/lib/pymodules/python2.6/gtk-2.0']
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
