[Qgis-developer] SpatiaLite very slow with QGIS 1.7
Jürgen E. Fischer jef at norbit.de
Sun Mar 20 18:58:13 EDT 2011
Hi Martin,
On Sun, 20. Mar 2011 at 18:32:41 +0100, Martin Dobias wrote:
> Thanks for the testing suite. I have run it with a profiler and found
> out that it is (surprisingly) caused by QgsSnappingDialog. It is
> created on application startup, each time when a layer is added to map
> layer registry it updates itself: creates tree widget items, combo
> boxes etc. Disabling the update slot connection it takes ~3s to open
> all the layers and quitting is instantaneous.
The code "updating" the layer list in the snapping dialog was constantly
removing everything and recreating all entries.   Fixed in r15545.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
