[Qgis-developer] rendering behavior options not available
    John C. Tull
    jctull at gmail.com
    Sun Mar 20 23:31:33 EDT 2011
Hi William,
I believe this all can be traced back to this:
http://trac.osgeo.org/qgis/changeset/8421
Although I am not sure if that is true of the option to turn the on/off when loaded. I manually turned on the 'qgis.new_layers_visible' in the plist file and it seems to work fine.
Ah, it appears that the "fix" for Mac rendering redraw problems was to disable the entire groupBox_5 in the qgsoptions.cpp file for Mac systems.
John
On Mar 20, 2011, at 6:12 PM, William Kyngesburye wrote:
> I wanted to test the recent [spatialite] loading speed issue by turning layers off before saving a project.  There is a QGIS render preference to turn on/off layers by default when adding them to a project, but it is greyed out (and checked on), along with the other render behavior options, # features to draw and render cache (unchecked).  I think it's always been greyed out as far back as I can remember.
> Why are these options present if they can't be changed?  Do I need to enable something in compilation?  Is it dependent on another option?  If they can't be changed at all, they shouldn't be shown in the application preferences.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Mon Dieu! but they are all alike.  Cheating, murdering, lying, fighting, and all for things that the beasts of the jungle would not deign to possess - money to purchase the effeminate pleasures of weaklings.  And yet withal bound down by silly customs that make them slaves to their unhappy lot while firm in the belief that they be the lords of creation enjoying the only real pleasures of existence....
> - the wisdom of Tarzan
> Qgis-developer mailing list
