[Qgis-developer] Help needed with PyQGIS
Learn Qgis learn.qgis at gmail.com
Wed Mar 23 03:02:02 EDT 2011
Hi Charlie,
I have check the environment path variables and everything is properly set.
On further R&D, I found that it is not able to find core.lib, gui.lib in
QGIS_INSTALLATION_DIR/PYTHON/QGIS.
I want to know that how do we generate core.lib and gui.lib ? Which project
is responsible for generating these library files. The project
"python_module_qgis_core" generated only core.pyd, it don't generate
core.lib.
Please let me know how do I generate above files ????
thanks in Advance.
QGIS Learner
On Thu, Mar 17, 2011 at 10:34 PM, Charlie Sharpsteen
<chuck at sharpsteen.net>wrote:
> On Wed, Mar 16, 2011 at 10:20 PM, Learn Qgis <learn.qgis at gmail.com> wrote:
>> Hi,
>> I am new to QGIS. I am trying to build the source code using CMAKE to
>> Visual Studio 2008 environment with python binding.
>> I am using Python 2.7, SIP 4.12.1 and PyQt 4.8.3
>> I am getting below error....
>> *Couldn't load PyQGIS.
>> Python support will be disabled.
>> Traceback (most recent call last):
>>   File "", line 1, in
>> ImportError: dynamic module does not define init function (initcore)
>> *Python version:
>> 2.7 (r27:82525, Jul  4 2010, 09:01:59) [MSC v.1500 32 bit (Intel)]
>> QGIS version:
>> 1.6.0-Copiapo 'Copiapo', exported
>> Python path:
>> ['D:/dev/cpp/build/src/app/**Debug/./python', 'C:/Documents and
>> Settings/Administrator/.qgis/**python', 'C:/Documents and
>> Settings/Administrator/.qgis/**python/plugins',
>> 'D:/dev/cpp/build/src/app/**Debug/./python/plugins',
>> 'E:\\Python27\\Lib\\site-**packages', 'E:\\Python27\\Lib',
>> 'D:\\dev\\cpp\\build\\src\\**app\\Debug', 'C:\\WINDOWS\\system32\\**python27.zip',
>> 'E:\\Python27\\DLLs', 'E:\\Python27\\lib\\plat-win',
>> 'E:\\Python27\\lib\\lib-tk', 'E:\\Python27']*
>> Please help me in resolving this error....
>> thanks in advance...
> Usually this means that Python could not find the PyQt module or could not
> load it for some reason.  Check your environment variables---specifically
> PATH and PYTHONPATH.
> -Charlie
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110323/801494a1/attachment.html
