[Qgis-developer] create "double" boundaries with new symbology engine
Otto Dassau dassau at gbd-consult.de
Wed Mar 23 15:16:58 EDT 2011
Hi Andreas,
thanks a lot for the hint. I almost managed to create a) and b). But I
don't understand exactly how to create a new Dash Dash Dot line with the "use
custom dash pattern" function. Can you give me a hint, how to do this?
Thanks a lot
 Otto
Am Wed, 23 Mar 2011 15:31:00 +0100
schrieb Andreas Neumann <a.neumann at carto.net>:
>  yes - both cases are possible. You can use the line offsets, custom
>  dashing and marker lines. Maybe you can even do without the markers.
>  Let me know if you need help.
>  Andreas
>  On Wed, 23 Mar 2011 15:13:28 +0100, Otto Dassau wrote:
> > Hi,
> > does the new symbology engine support to create complex double
> > boundaries as
> > shown in the attached image (see arrows).
> > a) A Dash Dash Dot boundary and inside a blue line
> > b) A boundary with Dashes and inside a line with Dots
> > Thanks a lot
> >   Otto
