[Qgis-developer] Print Composer question & Batch print multiple maps
Mayeul Kauffmann mayeul.kauffmann at free.fr
Wed Mar 23 16:29:46 EDT 2011
Hi Jordan
I read the ticket
In the "Scenarios tried" the following has not been tested.
I just tried with success an AO export to svg. I opened in Inkscape then
saved as PDF. Here you can print as poster in small pieces.
Also you can try the print as postscript function in the composer.
I have tried with middle size maps; tell me if it works for you.
Regards,
Mayeul
Le mercredi 23 mars 2011 à 11:57 -0700, Jordan Preston a écrit :
> I have tried to do this although receive an error.  The same as posted
> here
> http://trac.osgeo.org/qgis/ticket/3417
> --- On Wed, 3/23/11, Paolo Cavallini <cavallini at faunalia.it> wrote:
>         From: Paolo Cavallini <cavallini at faunalia.it>
>         Subject: Re: [Qgis-developer] Print Composer question & Batch
>         print multiple maps
>         To: qgis-developer at lists.osgeo.org
>         Date: Wednesday, March 23, 2011, 1:51 AM
>         Il giorno mar, 22/03/2011 alle 12.15 -0700, Jordan Preston ha
>         scritto:
>         > Hi,
>         > Perhaps you can point me in the right direction. I have a
>         very
>         > detailed map and would like to create say 20 zoomed in maps
>         for print,
>         > say 36" x 48"
>         Hi.
>         If I understand it correctly, you can just print to pdf and
>         let your
>         print manager split the large pdf into one series of pages,
>         deciding how
>         much overlap between pages etc.
>         All the best.
>         http://www.faunalia.it/pc
>         _______________________________________________
>         Qgis-developer mailing list
>         Qgis-developer at lists.osgeo.org
>         http://lists.osgeo.org/mailman/listinfo/qgis-developer
