[Qgis-developer] Australian Grid Datums (Ticket 3099)
Ramon Andinach custard at westnet.com.au
Wed Mar 23 19:26:13 EDT 2011
Hello,
Is it possible to get the following files included in the projections folder (/usr/share/proj or equivalent).
http://www.icsm.gov.au/icsm/gda/gdatm/national66.zip
http://www.icsm.gov.au/icsm/gda/gdatm/national84.zip
To work properly they need to be unzipped and renamed to agd66.gsb and agd84.gsb respectively.
They are licenced under the CC by A (Australia), as confirmed below, requiring only attribution to the ICSM.
This should then close ticket 3099 [1,2,3] and result in a bundle of happy Australians that would then roam across the country extolling how wonderful QGIS is :)
If they're too big to go in the distro, let me know and I'll rig some instructions into the wiki.
-ramon.
[1] http://trac.osgeo.org/qgis/ticket/3099
[2] Something roughly like this has been added to the ticket
[3] If it ends up that we're having trouble getting resulting QGIS generated AGD shape files recognised in other GIS packages (to Brett and myself the .prj files look a little weird, and Brett is currently checking this out) then we should use a new ticket for that.
Begin forwarded message:
> From: <icsm at ga.gov.au>
> Date: 24 March 2011 06:28:31
> To: <custard at westnet.com.au>
> Subject: RE: Copyright on AGD84 and AGD66 transformation grids [SEC=UNCLASSIFIED]
> Dear Ramon,
> Yes you're correct that the data is available under the Creative Commons licence.  If you use, or refer to it, in any publication, the only requirement is to attribute ICSM as the creator of the data, as outlined on the Creative Commons website http://creativecommons.org.au/learn-more/licences
> If you require further clarification, please do not hesitate to contact me again.
> Kind regards,
> Lesley
> -----Original Message-----
> From: custard [mailto:custard at westnet.com.au]
> Sent: Wednesday, 23 March 2011 16:31
> To: ICSM
> Subject: Copyright on AGD84 and AGD66 transformation grids
> Dear Lesley Waterhouse,
> I am writing to as if I can confirm the copyright status for the two AGD transformation grids found here:
> and linked from the GDA Techincal Manaul's webpage:
> http://www.icsm.gov.au/icsm/gda/gdatm/index.html
> To my understanding they are covered by the Creative Commans by Attribution Licence for Australia (v3.0). Is this correct?
> If not, what copyright licencing applies to it?
> Yours sincerely,
> Ramon Andinach
