[Qgis-developer] Raster providers
Radim Blazek radim.blazek at gmail.com
Thu Mar 31 06:24:13 EDT 2011
On Thu, Mar 31, 2011 at 11:32 AM, Jürgen E. <jef at norbit.de> wrote:
> That shouldn't be a problem projectionwise.
> It found EPSG:4148 because that has the same projection parameters as EPSG:4326
> and the WKT string doesn't have any information about which EPSG is desired.
> Otherwise the description and authid would change, still that wouldn't change
> the projection.
> Or am I missing something else that is lost?
OK. Giovanni, can you verify if the problem is still present? Check
also layer's metadata and debug output as missing EPSG can lead to
confusion described above.
Radim
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden               http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
