[Qgis-developer] Get the qgis project into the browser...
Christopher Stark christopherstark at gmx.de
Tue Nov 8 03:05:47 EST 2011
Hi Andreas,
I would like to choose the easiest way of displaying a complex
Qgis-project within a browser. I'm not sure if doing this with WMS or
the Qgis webclient is the easiest way.
Basically I want something like tilemill but with tilemill the whole
styling thing is a bit too complicated. So if it's possible with qgis to
simply display a complex map-projects with diagrams, raster-layers and
labeling in the browser that would be perfect for me. Later I would like
to have a look into TileCache (in order to use this for a website) but
for now being able to simply display the project in the browser is all I
want.
Christopher
Am 07.11.2011 20:59, schrieb Andreas Neumann:
> Hi Christopher,
> What are your goals? To setup a WMS server or to setup a Web-GIS with
> QGIS Webclient?
> One option to test if QGIS server is working properly as a WMS server,
> is to use QGIS desktop as a WMS client.
> QGIS web client is a different story to setup. First let us know what
> your goals are.
> Andreas
> On 11/07/2011 04:28 PM, Christopher Stark wrote:
>> Hi,
>> I tried to make this qgis project visible  in the browser:
>> http://www.christopherstark.de/extern/qgis-server2.jpg
>> I installed qgis server and it seems to work. When I use this URL below
>> (I think I changed it correctly to my settings) in the browser there is
>> only a white screen and no map.
>> http://localhost/cgi-bin/qgistest1/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=54.215710,10.017432,50.05100,15.0004508&CRS=EPSG:4326&WIDTH=1077&HEIGHT=552&LAYERS=ostdeutschland-mercator2&FORMAT=image/png&DPI=96
>> Can anyone here help me to get the right url in order to make the map
>> visible in the browser?
>> best regards
>> Christopher
>> Am 19.10.2011 10:39, schrieb Noli Sicad:
>>> I guess you have read this,
>>> Noli
>>> On 10/19/11, Noli Sicad <nsicad at gmail.com> wrote:
>>>> Hi Christopher,
>>>> The code that I posted is not complete.
>>>> Did you include OpenLayers.js and CSS for the openlayers?
>>>> Visit this link and to see the whole code,
>>>> http://linfiniti.com/2011/09/qgis-server-with-tilecache/
>>>> It seem the link is not working now. However, you browse the any
>>>> openlayers example and see how the post that I copied from Tim's is
>>>> used.
>>>> Noli
>>>> On 10/19/11, Christopher Stark <christopherstark at gmx.de> wrote:
>>>>> Hi Noli,
>>>>> which parts in this code do I have to modify for my Qgis Server Project?
>>>>> I pasted this code into a html (index2.html) file within var/www/  but
>>>>> there is nothing displayed when I open
>>>>> localhost/index2.html
>>>>> best regards
>>>>> Christopher
>>>>> Am 16.10.2011 04:40, schrieb Noli Sicad:
>>>>>>> The most common web client being Openlayers, this will require work on
>>>>>>> your part, mainly a few lines of javascript in a web page. You might be
>>>>>>> able to use it directly in Geocommons or in Mapfish (also takes setup).
>>>>>> This is how Tim used it for OpenLayers client (below).
>>>>>> Very few documentation how to actually use in OpenLayers and WMS.
>>>>>> Noli
>>>>>> <script type="text/javascript">
>>>>>>         var map, layer;
>>>>>>         function init(){
>>>>>>           var MapOptions = {
>>>>>>             projection: new OpenLayers.Projection("EPSG:32633"),
>>>>>>             units: "m",
>>>>>>             masxScale: 19567.879237500,
>>>>>>             //maxScale:1000,
>>>>>>             //minScale:17000000,
>>>>>>             numZoomLevels: 10,
>>>>>>             resolutions: [19567.8792375, 9783.93961875,
>>>>>> 4891.969809375, 2445.9849046875, 1222.99245234375, 611.496226171875,
>>>>>> 305.7481130859375, 152.87405654296876, 76.43702827148438,
>>>>>> 38.21851413574219],
>>>>>>             maxExtent: new
>>>>>> OpenLayers.Bounds(-918304.23600184,6418410.00099619,1957227.50491800,7976533.94886646),
>>>>>>             fractionalZoom: false,
>>>>>>             transitionEffect:"resize",
>>>>>>           map = new OpenLayers.Map( 'map', MapOptions );
>>>>>>           layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
>>>>>>               "http://maps.linfiniti.com/cgi-bin/tilecache.cgi",
>>>>>>               {layers: 'utno-test'} );
>>>>>>           map.addLayer(layer);
>>>>>>           map.zoomToMaxExtent();
>>>>>>     </script>
>>>>>>   </head>
>>>>>>   <body onload="init()">
>>>>>>     <div id="map" class="map"></div>
>>>>>>   </body>
>>>>>> _______________________________________________
>>>>>> Qgis-developer mailing list
>>>>>> Qgis-developer at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111108/36cb6c32/attachment.html
