[Qgis-developer] Plugin metadata in a text file
Nathan Woodrow
madmanwoo at gmail.com
Thu Nov 10 04:01:12 EST 2011
I don't mind if the change log isn't stored in the ini, no big deal really.
Was just throwing it out there.
In the end it wouldn't be that hard for the web app to look for a CHANGELOG
file and read that in. In the end we just have to set something up with
easy to use and follow conventions so that it makes the plugins consistent.
Convention over configuration.
- Nathan
On Thu, Nov 10, 2011 at 6:56 PM, Alessandro Pasotti <apasotti at gmail.com>wrote:
> 2011/11/10 Sandro Santilli <strk at keybit.net>:
> > On Thu, Nov 10, 2011 at 05:55:06PM +1000, Nathan Woodrow wrote:
> >> Yeah. It would be easier from a developer point of view. I can just
> stick
> >> my change log in there and the web app just reads it in saving me the
> time
> >> to have to fill it out plus then when you download it you have a central
> >> place to look for the change log.
> > Mind you: a change log grow rate sounds pretty different from a
> > configuration directive list grow rate.
> > Your changelog might get huge...
> > How about using a different file for that ?
> I think the idea is to only store changes from the previous version,
> each version is stored separately on the plugins app.
> BTW I'm also concerned about storing potentially huge text blobs
> inside an ini file.
> I'm not very skilled with that format, is that ok for large text blobs
> ? I thought it was best suited for kwp.
> Alessandro Pasotti
> w3: www.itopen.it
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111110/4691f4e2/attachment-0001.html
