[Qgis-developer] Feedbacks about Qgis Server
Andreas Neumann a.neumann at carto.net
Mon Nov 14 12:01:12 EST 2011
 Hi Kimaidu.
 Thank you for your constructive remarks.
 Many of the issues you raise here were also identified before or at the
 recent developer meeting. See also
 http://www.qgis.org/wiki/QGISWebClientIdeas
 The issue with the different scales are really annoying, so why dont we
 make the 96 dpi the default? Do you really think it is much slower? BTW
 - we already get 96dpi images, only OL seems to calculate the scale with
 72dpi. We even try to detect the dpi when loading the client. Not sure
 if this works properly ... Thanks anyway for the hint. I will test it.
 An improved GetLegendGraphics with user configurable sizes is already
 requested and will be a paid development/improvement from Sourcepole.
 GetCapabilities improvements: at the meeting we decided to use a web
 map context (similar to GetCapabilities) but more configurable to
 transport settings we want, e.g the initial layer visibility, etc.
 Thanks,
 Andreas
 On Mon, 14 Nov 2011 16:47:27 +0100, kimaidou wrote:
> Hi devs,
>   During the development of Lizmap, we have needed some features not
> yet implemented, or encountered some problems. I would like to write
> down in the email all the things which seem interesting as a
> feedback,
> and all the questions I have. Please see it as a user contribution,
> and not as criticism if course. (I am using QGIS 1.7.1). I will open
> tickets if needed depending on your answers.
> GENERAL
> * DPI : I you want to have the exact same renderding for Qgis Desktop
> and Qgis Server, you have to use DPI=96 in the WMS client (e.g. in
> OpenLayers, you have to set the option : OpenLayers.DOTS_PER_INCH =
> 96). For webmapping point of view, increasing DPI from 72 (default in
> web applications) to 96 is not a good thing, as it increases the size
> of images received by the client. It could be great to set in Qgis
> project properties the DPI for the rendering in Qgis Desktop. This
> way, the user will have the choice to create one project in 72 DPI
> for
> web purpose only. The web client will then be able to ask images with
> the same 72 dpi, and the rendering will remain identical between
> desktop and server. I do not know if it is an easy thing to do, or a
> big development to achieve this...
> GETCAPABILITIES
> * Layers meta-data
> At present, Qgis Server send an empty "Abstract" property for each
> layer in the GetCapabilities request, since it is not possible to
> write down this abstract in Qgis Layer properties dialogue. It could
> be good to have this possibility for groups too. In Lizmap plugin,
> the
> user can manually edit the Abstract field for each group or layer,
> but
> it would be better imho to have it directly in Qgis.
> GETLEGENDGRAPHICS
> * SVG icon for point layer : When you change the DPI parameters, the
> text size changes, but the size of the SVG icon does not
>  - 96 DPI :
> http://178.32.101.237/lizmap/index.php/lizmap/service/?PROJECT=alaska&pp=demo&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetLegendGraphics&LAYERS=airports&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&WIDTH=150&DPI=96
> [1]
>  - 300 DPI :
> http://178.32.101.237/lizmap/index.php/lizmap/service/?PROJECT=alaska&pp=demo&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetLegendGraphics&LAYERS=airports&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&WIDTH=150&DPI=300
> [2]
> One solution could be to have 2 different parameters to change text
> and icon size independently ?
> * Legend of a group shows also layers that are not visible (min and
> maxscale layer property). I tried to use the SCALE parameter to check
> this behaviour. The getLegendGraphics returns all the layers of a
> group (if called with the group name as the LAYERS parameter). For
> exemple, a group called "hydro" and containing 2 layers "main river"
> (visible at all scales) and "minor rivers" visible only at scales =<
> 5
> 000 000. If I ask the legend for this group "hydro", I would like the
> server to only return the legend of "major rivers" with SCALE=10 000
> 000, and both layers with SCALE=2 000 000.
> QGIS API
> * Get groups state : I could not figure out how to get the toggled
> state of groups with the api. I tried :
> self.iface.legendInterface().isGroupVisible(myGroups.indexOf(myId))
> But it seems to provide another type of information.
>  The idea is to know if a group is toggled or not in the project.
> I hope I was clear enough :)
> kimaidou
> Links:
> [1]
> http://178.32.101.237/lizmap/index.php/lizmap/service/?PROJECT=alaska|+|amp|+|pp=demo|+|amp|+|SERVICE=WMS|+|amp|+|VERSION=1.3.0|+|amp|+|REQUEST=GetLegendGraphics|+|amp|+|LAYERS=airports|+|amp|+|EXCEPTIONS=application%2Fvnd.ogc.se_inimage|+|amp|+|FORMAT=image%2Fpng|+|amp|+|TRANSPARENT=TRUE|+|amp|+|WIDTH=150|+|amp|+|DPI=96
> [2]
> http://178.32.101.237/lizmap/index.php/lizmap/service/?PROJECT=alaska|+|amp|+|pp=demo|+|amp|+|SERVICE=WMS|+|amp|+|VERSION=1.3.0|+|amp|+|REQUEST=GetLegendGraphics|+|amp|+|LAYERS=airports|+|amp|+|EXCEPTIONS=application%2Fvnd.ogc.se_inimage|+|amp|+|FORMAT=image%2Fpng|+|amp|+|TRANSPARENT=TRUE|+|amp|+|WIDTH=150|+|amp|+|DPI=300
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
