[Qgis-developer] Re: Redmine - organizing Qgis web clients projects
Werner Macho werner.macho at gmail.com
Wed Nov 16 05:04:56 EST 2011
Hi!
I am not responsible for the redmine organization .. but your suggestion
sounds good ..
so - from my point - if we collect all webclients (currently 2) at one
place .. it's a good idea ..
so +1 from me and go ahead until someone else is saying stop (but i
guess that will not happen)
regards
Werner
Am 16.11.2011 10:59, schrieb kimaidou:
> Hi list
> I reopen my previous email, since I get no answer. Which is responsible
> of the redmine organisation ?
> 2011/11/13 kimaidou <kimaidou at gmail.com <mailto:kimaidou at gmail.com>>
>     Hi list,
>        I would like to use the hub to publish documentation and source
>     code for Lizmap plugin and Lizmap web application. As Lizmap has the
>     same goal as QgisWebClient, I  think it will help users if we create
>     one parent project called "Qgis Web Clients" in the same level as
>     Qgis Android. This project will contain 2 sub-projects :
>     QgisWebClient and Lizmap Web Client.
>     I will then create a second project Lizmap Plugin under "User Plugins"
>     Let me know if this proposal sounds ok.
>     Cheers
>     Michael Douchin aka Kimaidou
> Qgis-developer mailing list
