[Qgis-developer] Call for packaging: QGIS 1.7.2
William Kyngesburye woklist at kyngchaos.com
Wed Nov 16 09:43:55 EST 2011
There should not be a problem, now or in the past.  As I mentioned before, pyspatialite is in my Sqlite framework.  Qspatialite works for me.
On Nov 15, 2011, at 11:56 PM, Patrice Vetsel wrote:
> Is it "PySpatiaLite python module required for QSpatialiLite" fixed ?
> Regards
> Le 15 nov. 2011 à 03:55, William Kyngesburye a écrit :
>> Ready here on OS X.
>> On Nov 13, 2011, at 6:05 AM, Werner Macho wrote:
>>> Hi Folks
>>> Today I have branched QGIS version release-1_7_2 - the second maintenance
>>> release on the 1.7.x branch.
>>> The source tarball is here:
>>> http://qgis.org/downloads/qgis-1.7.2.tar.bz2
>>> and the md5 checksum is here:
>>> http://qgis.org/downloads/qgis-1.7.2.tar.bz2.md5
>>> You can check out this branch (depending on your personal settings) using:
>>> git fetch origin
>>> git branch --track release-1_7_2 origin/release-1_7_2
>>> If packagers would be so kind as to update http://download.qgis.org
>>> with links to their latest wares, it will be appreciated. I'll give a
>>> few days (and until we have Windows binaries at minimum) before making
>>> the announcement to the world.
>>> Please note that I have reinstated maintenance of the CHANGELOG file
>>> in the root of the source tree, so consult that (or the
>>> help->about->whats new? tab after building) to see what changes were
>>> made. Some of the last minute commits will not be mentioned there.
>>> There are no new features in the release, only bug fixes and small
>>> tweaks.
>>> This will be the last 1.7.x release.
>>> Best regards
>>> Werner
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> [Trillian]  What are you supposed to do WITH a maniacally depressed robot?
>> [Marvin]  You think you have problems?  What are you supposed to do if you ARE a maniacally depressed robot?  No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
>> - HitchHiker's Guide to the Galaxy
> Patrice Vetsel
> patrice at kagou.fr
> http://blog.kagou.fr
The equator is so long, it could encircle the earth completely once.
