[Qgis-developer] Re: Redmine - organizing Qgis web clients projects
Tim Sutton lists at linfiniti.com
Mon Nov 21 05:02:19 EST 2011
Hi
On Mon, Nov 21, 2011 at 11:54 AM, kimaidou <kimaidou at gmail.com> wrote:
> Tim,
> Thanks for having moved the "Lizmap Web Client" project under the "Web
> clients" project.
no problem
> I have just created a "Lizmap Plugin" project. Please move it under "User
> plugins". Thanks in advance !
ok done!
>> I added mercurial support too (untested).
> Thanks. A problem though : Mercurial support in Redmine is not very good.
> The only way to have a repository is :
> * create an folder somewhere in the server, and clone from my repository
> here using SSH (So I will need to have full access to the server, which is
> the wrong way...)
> * Then Redmine will refresh the repository each time a user reads the
> repository tab.
> * Pbm : it will only be read access through redmine (just showing list of
> commits) : Redmine does not give any pull nor push rights binded to redmine
> users
> Conclusion : Mercurial is not a good choice in Redmine if the server does
> not belong to you :)  I do not knwo yet which other solution I will use :
> * use bitbucket and just give a link in qgis hub
> * use Git for full integration
In general the same issues exist with other protocols I think. I don't
know mercurial well enough to offer further advice. Pirmin would
probably be in a better position to help.
Regards
Tim
> Regards
> Kimaidou
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
