[Qgis-developer] Recent additions to the python plugins web app
Tim Sutton lists at linfiniti.com
Tue Nov 22 06:55:06 EST 2011
Hi
On Tue, Nov 22, 2011 at 1:35 PM, Alessandro Pasotti <apasotti at gmail.com> wrote:
> Hi,
> Today I've added a couple of new fields and features to the web app:
> -    Added tracker, repository, deprecated (#18, #19, #4265)
> those new fields are optional but a warning is issued if thy are
> empty, the message also suggests to create a repository on
> hub.qgis.org
> the deprecated field marks the plugin with red in the lists and in the
> details view
> -    Added new plugin fields to the XML
> the plugins.xml file also shows the new fields
> -    Enabled DB cache
> DB caching for anonymous users is now active
> -   Added the ajax template, which only shows the inner page content
> -   Added IS_NAKED context var for ajax/frameless calls
> This can be used to implement "naked" views, just add ajax=1 to the
> query string, for example:
> http://plugins.qgis.org/plugins/QuickWKT/?ajax=1
> -    Fixed some validation errors and improved error messages
> Error messages are now more verbose and try to suggest a solution for
> most common errors
> -    Added page titles vary on application!
> Plugins, Snippets etc. can now have different page titles
> Bug reports and suggestion are welcome.
Great stuff Ale - thanks for these updates!
regards
Tim
> Alessandro Pasotti
> w3:   www.itopen.it
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
