[Qgis-developer] Critical problems with 1.7.2 from ubuntu binaries
Agustin Lobo alobolistas at gmail.com
Tue Nov 29 01:45:41 EST 2011
Did you install it from ubuntugis-unstable or from qgis.org? When did
you install it?
The problem has been solved here upon reinstalation, but an student had
the same problem on another machine.
Perhaps the binaries have been wrong for a while on ubuntugis-unstable?
Agus
2011/11/29 Noli Sicad <nsicad at gmail.com>:
> How you got the error?
> I am using Ubuntu 10.04 lucid with 1.7.2.
> I don't have problems with the python and c++ plugins.
> Noli
> On 11/29/11, Agustin Lobo <alobolistas at gmail.com> wrote:
>> After updating to 1.7.2 in ubuntu 10.4 LTS using the
>> ubuntugis-unstable repo, the CRS cannot be set:
>> "Could not open CRS database /resources/srs.db<br>Error(14): unable to
>> open database file!
>> and almost all plugins are gone (including plugin installer).
>> Agus
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
