[Qgis-developer] problems with Identify and select tool
Andreas Neumann a.neumann at carto.net
Tue Nov 29 05:51:48 EST 2011
 yes - I have similar problems.
 Jürgen is working on it. It is a side effect of recent modifications on
 the PostgreSQL provider.
 Andreas
 On Tue, 29 Nov 2011 10:43:30 -0000, James Stott wrote:
> Has anyone else had problems with the identify and the select tool?
> They seem to have appeared in the last couple of days as it worked
> last week.
> I get an error message whenever I click on the map with either tool.
>  It does this for every vector layer. It still returns values for the
> raster layer I am using as background mapping.
> I am running 1.9.90.7 OSgeo4W.
> The error is as follows:
> Query Failed:
> 1 cursor states lost.
> SQL: declare qgisf11 binary cursor for select
> "gid",asbinary("the_geom",'NDR'),"name"::text,"theme"::text,"themname"::text,"themid"::text,"status"::text,"perimeter"::text,"area"::text,"gridref"::text
> from "data"."awi" where "the_geom" &&
> setsrid('BOX3D(177120.8977402151504066 59808.3671354566467926,
> 177233.5664761684311088 59921.0358714099420467)'::box3d,27700) and
> intersects("the_geom",setsrid('BOX3D(177120.8977402151504066
> 59808.3671354566467926, 177233.5664761684311088
> 59921.0358714099420467)'::box3d,27700)))
> Result: 7 (ERROR: syntax error at or near ")"
> LINE 1: ...33.5664761684311088
> James Stott BSc (Hons) MSc | Senior Professional
> Nicholas Pearson Associates | 30 Brock Street | Bath | BA1 2LN
> T: 01225 445548 | M: -
> http://www.npaconsult.co.uk/
> http://www.npaconsult.co.uk/http://www.npaconsult.co.uk/about-news.asp
> http://www.npaconsult.co.uk/terms.asp
> This Electronic Transmission is intended only for the attention of
> the addressee. It may contain privileged and confidential
> information.
> If you are not the person for whom it is intended, you must not copy,
> distribute or take any action in reliance on it. If you have received
> this electronic transmission in error please notify us immediately by
> telephone, delete the transmission and destroy any hard copies.
> Nicholas Pearson Associates has used all reasonable efforts to ensure
> that this message and any attachments are free from viruses.
> Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel:
> +44 (0) 01225 445548, Fax: +44 (0) 01225 312387, Website:
> Qgis-developer mailing list
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
