[Qgis-user] Re: [Qgis-developer] Critical problems with 1.7.2 from ubuntu binaries
Etienne Tourigny etourigny.dev at gmail.com
Wed Nov 30 19:32:14 EST 2011
I think I misunderstood the problem, the ubuntugis-unstable repos only
allows 1 version of qgis installed at a time.
If you need to uninstall qgis-1.7.0 before upgraging to 1.7.2, then
there surely must be a problem with the upgrade process in the .deb?
On Wed, Nov 30, 2011 at 5:21 PM, David J. Bakeman <dbakeman at comcast.net> wrote:
> Etienne Tourigny wrote:
>> shouldn't qgis be packaged in such a way to avoid multiple (minor)
>> versions of QGIS?
>> i.e. change the package names to  1.7 instead of 1.7.0 / 1.7.1 / 1.7.2 ?
>> There really is no need to have the old packages around, especially
>> with this issue.
> I respectfully disagree.  It's not that the old packages need to be around
> it's that they are
> out there already.
> People have them some people either can't or won't be
> able to upgrade
> them and when those people have questions it's important that the developers
> and others
> know exactly what version of the software is being discussed.
>> Regards,
>> Etienne
>> On Tue, Nov 29, 2011 at 8:09 AM, Noli Sicad<nsicad at gmail.com>  wrote:
>>>> reproduced the problem by installing on another machine with ubuntu
>>>> 10.04 . Running qgis from the command line I get:
>>>> alobo at delia:~$ qgis
>>>> Warning: loading of qgis translation failed
>>>> [/usr/share/qgis/i18n//qgis_en_US]
>>>> Warning: loading of qt translation failed
>>>> [/usr/share/qt4/translations/qt_en_US]
>>>> Warning: Couldn't load Python support library: Cannot load library
>>>> /lib/qgispython: (/lib/libqgispython.so: cannot open shared object
>>>> file: No such file or directory)
>>> In ubuntu 10.04 Lucid, you have to install
>>> - python-qgis 1.7.2~Lucid1
>>> - python-qgis-common 1.7.2-1~Lucid1
>>> If you upgrade from other version (e.g. 1.7.0), you have to remove
>>> first the old version then install 1.7.2.
>>> Noli
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
