[Qgis-developer] Re: [Qgis-user] Offline editing not working on some layer types.
Noli Sicad nsicad at gmail.com
Thu Oct 13 18:50:58 EDT 2011
What exactly the name of this plugin?
I typed "offline" in the filter for QGIS python plugin installer,
nothing is showing up.
Noli
On 10/14/11, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Hi All,
> I was trying to use the offline editing plugin for some field work but it
> doesn't seem to want to convert the layers to offline for me.
> The layers are all MapInfo .TAB files when running convert to offline the
> plugin sits for a while then goes back to the map canvas.  This is the
> output in my Windows XP DebugView:
> [6032] d:\src\qgis\src\app\qgscustomization.cpp(778) :
> (QgsCustomization::customizeWidget) objectName =
> QgsOfflineEditingPluginGuiBase event type = 17
> [6032] d:\src\qgis\src\app\qgscustomization.cpp(780) :
> (QgsCustomization::customizeWidget) QgsOfflineEditingPluginGui x QDialog
> (QgsCustomization::customizeWidget) objectName =  event type = 17
> (QgsCustomization::customizeWidget) QMessageBox x QDialog
> QgsOfflineEditingProgressDialogBase event type = 17
> (QgsCustomization::customizeWidget) QgsOfflineEditingProgressDialog x
> QDialog
> [6032] d:\src\qgis\src\core\qgsmaplayer.cpp(53) : (QgsMapLayer::QgsMapLayer)
> lyrname is 'Buildings (offline)'
> [6032] d:\src\qgis\src\core\qgsmaplayer.cpp(59) : (QgsMapLayer::QgsMapLayer)
> layerName is 'Buildings (offline)'
> [6032] d:\src\qgis\src\core\qgsproviderregistry.cpp(363) :
> (QgsProviderRegistry::provider) Library name is
> C:/OSGeo4W/apps/qgis-dev/plugins/spatialiteprovider.dll
> [6032] d:\src\qgis\src\core\qgsproviderregistry.cpp(369) :
> (QgsProviderRegistry::provider) Loaded data provider library
> [6032] d:\src\qgis\src\core\qgsproviderregistry.cpp(370) :
> (QgsProviderRegistry::provider) Attempting to resolve the classFactory
> function
> [6032] d:\src\qgis\src\core\qgsproviderregistry.cpp(377) :
> (QgsProviderRegistry::provider) Getting pointer to a dataProvider object
> from the library
> [6032] d:\src\qgis\src\providers\spatialite\qgsspatialiteprovider.cpp(4102)
> : (QgsSpatiaLiteProvider::SqliteHandles::openDb) New sqlite connection for
> C:/offline.sqlite
> [6032] d:\src\qgis\src\providers\spatialite\qgsspatialiteprovider.cpp(4123)
> : (QgsSpatiaLiteProvider::SqliteHandles::openDb) Connection to the database
> was successful
> [6032] d:\src\qgis\src\providers\spatialite\qgsspatialiteprovider.cpp(459) :
> (QgsSpatiaLiteProvider::QgsSpatiaLiteProvider) Invalid SpatiaLite layer
> [6032] d:\src\qgis\src\core\qgsproviderregistry.cpp(388) :
> (QgsProviderRegistry::provider) Instantiated the data provider plugin
> [6032] d:\src\qgis\src\core\qgsproviderregistry.cpp(389) :
> (QgsProviderRegistry::provider) provider name: spatialite
> [6032] d:\src\qgis\src\core\qgsproviderregistry.cpp(399) :
> (QgsProviderRegistry::provider) Invalid data provider
> [6032] d:\src\qgis\src\core\qgsvectorlayer.cpp(2843) :
> (QgsVectorLayer::setDataProvider)  unable to get data provider
> Seems if you do the same with using Shapefiles everything works fine.
> Anyone had this problem before?
> - Nathan
