[Qgis-developer] Installed Qgis on Ubuntu - what do I do next?
Giovanni Manghi giovanni.manghi at gmail.com
Fri Oct 14 15:50:12 EDT 2011
> What should I do as first steps after installing?
if working correctly, the address
http://localhost/cgi-bin/qgis_mapserv.fcgi
should return
<ServiceExceptionReport version="1.3.0"><ServiceException
code="OperationNotSupported">Please check the value of the REQUEST
parameter</ServiceException></ServiceExceptionReport>
Then just create a project in QGIS (use absolute paths) and in the
project properties configure the parameters in the "WMS server" tab.
Create a folder in
/usr/lib/cgi-bin/
and copy into it your QGIS project and a copy of qgis_mapserv.fcgi
your server address will be
http://localhost/cgi-bin/myprojectfolder/qgis_mapserv.fcgi
cheers
-- Giovanni --
