[Qgis-developer] Bison 2.3 error When Building QGIS for Snow Leopard
Mars Sjoden aurorageomatics at gmail.com
Sat Oct 15 14:17:22 EDT 2011
Interestingly getting errors on make install for qgsspatialindex
make[2]: *** [src/core/CMakeFiles/qgis_core.dir/qgsspatialindex.cpp.o] Error
1
make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
On Sat, Oct 15, 2011 at 11:06 AM, Mars Sjoden <aurorageomatics at gmail.com>wrote:
> Thank You!
> Amazing how much help you have been.
> How do I build QGIS with Debug=true?  as a side note
> On Sat, Oct 15, 2011 at 11:03 AM, William Kyngesburye <
> woklist at kyngchaos.com> wrote:
>> I found that cmake still uses the system bison even if a different one is
>> first in the PATH.  You need to force cmake to use yours with a configure
>> option:
>> -D BISON_EXECUTABLE=/usr/local/bin/bison
>> assuming you installed bison 2.4 in /usr/local.
>> On Oct 15, 2011, at 12:50 PM, Mars Sjoden wrote:
>> > I been running through the Build instructions for QGIS Mac OS X on the
>> QGIS Wiki,
>> > ** I remembered to comment out "QwtSVGItem" in the qwtconfig.pri file as
>> it stumbles on finding the x_86_64 framework from the universal framework.
>> > However when building QGIS I receive an error that Snow Leopard only has
>> BISON 2.3 and at least 2.4 is needed.
>> > I built 2.4.3 Bison but error still throws, unable to find the new Bison
>> build?
>> > Just wondering what my next best step is?
>> > I would like to build QGIS with debug flag to help find better crash
>> info.
>> > Thanks!!
>> > Mars
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "This is a question about the past, is it? ... How can I tell that the
>> past isn't a fiction designed to account for the discrepancy between my
>> immediate physical sensations and my state of mind?"
>> - The Ruler of the Universe
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111015/1c4d468b/attachment-0001.html
