[Qgis-developer] Installed Qgis on Ubuntu - what do I do next?
Christopher Stark christopherstark at gmx.de
Mon Oct 17 06:40:05 EDT 2011
Hi Marco,
thanks for this. I downloaded the qgis-web-client.
I get this output:
http://localhost/qgis-web-client/index.xml
QGIS WebclientQGIS ServerOSGEO LiveNatural Earth
WMS Get Capabilities
Responsible: OSGEO Live maintainers
When I click on the links "natural earth" or wms get capabilities" there
comes an error page "not found".
Can you tell me how I display my qgis project file with this web-client?
I didn't understand their documentation.
best regards
Christopher
Am 16.10.2011 08:37, schrieb Marco Hugentobler:
> Hi Christoper
> As others pointed out, there are many WMS clients with a graphical interface.
> QGIS webclient provides a java script client adapted to the possibilities of
> QGIS server (e.g. web based printing is supported out ot the box).
> Source code and documentation are here:
> https://github.com/qgis/qgis-web-client
> Regards,
> Marco
> Am Samstag, 15. Oktober 2011, 18.43:07 schrieb Christopher Stark:
>> Hi Marco,
>> thank you this works. Is there a more comfortable way of displaying a
>> map - with a web-frontend-page or do I have to type in every command
>> manually like this
>> e.g.:
>> http://localhost/cgi-bin/world/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&
>> REQUEST=GetMap&BBOX=-36.215710,6.817432,-9.700450,58.551008&
>> CRS=EPSG:4326&WIDTH=1077&HEIGHT=552&LAYERS=Continent,Country,Cities&
>> STYLES=,,&FORMAT=image/jpeg&DPI=96
>> It seems to be very complicated and time consuming to work like this (as
>> I'm a big GUI-fan)
>> Best regards
>> Christopher
>> Am 15.10.2011 16:25, schrieb Marco Hugentobler:
>>> Hi Christopher
>>> This error message shows that it works (you just did not make a valid WMS
>>> request). To publish your project, you need to give the file path to the
>>> .qgs project in the url and the wms request parameters.
>>> http://localhost/cgi-bin/qgis_mapserv.fcgi?map=/home/me/myproject.qgs&
>>> is the WMS url
>>> bin/qgis_mapserv.fcgi?map=/home/me/myproject.qgs&SERVICE=WMS&REQUEST=GetC
>>> apabilities
>>> should return an xml document with the available layer, styles, crs, etc.
>>> Regards,
>>> Marco
>>> Am Samstag, 15. Oktober 2011, 12.23:56 schrieb Christopher Stark:
>>>> Hi,
>>>> thank you. I did all this but now I get this error message:
>>>> This XML file does not appear to have any style information associated
>>>> with it. The document tree is shown below.
>>>> <ServiceExceptionReport version="1.3.0"><ServiceException
>>>> code="ServiceNotSpecified">Service not specified. The SERVICE parameter
>>>> is mandatory</ServiceException></ServiceExceptionReport>
>>>> Questions below:
>>>> Am 14.10.2011 21:50, schrieb Giovanni Manghi:
>>>>>> What should I do as first steps after installing?
>>>>> if working correctly, the address
>>>>> should return
>>>>> code="OperationNotSupported">Please check the value of the REQUEST
>>>>> parameter</ServiceException></ServiceExceptionReport>
>>>>> Then just create a project in QGIS (use absolute paths) and in the
>>>>> project properties configure the parameters in the "WMS server" tab.
>>>> which paramenters are important here? What does absolute paths mean in
>>>> this regard
>>>>> Create a folder in
>>>>> /usr/lib/cgi-bin/
>>>>> and copy into it your QGIS project and a copy of qgis_mapserv.fcgi
>>>>> your server address will be
>>>>> http://localhost/cgi-bin/myprojectfolder/qgis_mapserv.fcgi
>>>>> cheers
>>>>> -- Giovanni --
>>>> Best regards
>>>> Christopher
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111017/e079d33c/attachment.html
