[Qgis-developer] adding python interpreter to QGis mapserver to expose analysis routines
G. Allegri giohappy at gmail.com
Thu Oct 20 15:00:31 EDT 2011
I imagine a plugin system, similar to Qgis Desktop, where every service is
discovered/registered if available in certain library paths.
For the Python side I see two features that could be supplied:
 - Provide a qgispython to the services that require it to run python
scripting. We can reuse a code very similar (the same?) as in Qgis Desktop
 - Design a Python interface to "control" the Server. This would permit to
write Python frontends to the server, and incorporate Qgis Server inside
Python server projects
giovanni
2011/10/20 Martin Dobias <wonder.sk at gmail.com>
> On Wed, Oct 19, 2011 at 7:17 PM, G. Allegri <giohappy at gmail.com> wrote:
> > That would ne a very interesting architecture Martin.
> > Each Service would manage its on requirements, for example its own
> internal
> > bindings to Python or whatever.
> > I'm not sure about the "fastgi nature" of the services. The server has a
> an
> > fcgi interface, ok, but the services should be indipendent from this
> > specific interface. The Server could be deployed in a different fashion,
> but
> > the services should ignore this.
> Sure, it does not have to be bound specifically to FastCGI so that in
> future other gateway interfaces could be used.
> Martin
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111020/3128b235/attachment.html
