[Qgis-developer] adding python interpreter to QGis mapserver to expose analysis routines
Marco Hugentobler marco.hugentobler at sourcepole.ch
Fri Oct 21 09:00:38 EDT 2011
> I think that the main benefit would be having a single interface to manage,
> both on the side of fcgi configurations (eg Apache) and global, server,
> configurations.
> I imagine that one could expose some services depending on the overall
> configuration, or per user, or per domain, etc.
> Geoserver let services share functionalities, being "beans" managed by the
> server context available to any service. Anyway this could be a future
> feature (I suppose it would take not a small time to be designed and
> implemented), but having a single gateway opens to this possibility too.
Ok, that leads probably back to the discussion wether to use apache config &
fcgi settings & an existing service proxy (SecureOWS & co.) vs. have a QGIS
module for user configuration and management.
With QGIS, a service can use any function in core/analysis library.
Additionally, Python webservices might directly use qgis bindings and python
plugin functionality by importing the relevant classes (correct me if I'm
wrong).
Is there a use-case where it is necessary to manage the functionality by a
central server instance?
Regards,
Marco
Am Freitag, 21. Oktober 2011, 12.07:21 schrieb G. Allegri:
> 2011/10/21 Marco Hugentobler <marco.hugentobler at sourcepole.ch>
> > Hi all
> > It would be great to have a mapscript equivalent for QGIS server, so the
> > possibility to modify the request before it arrives at QgsWMSServer
> > class.
> > > GeoServer will provide WMS, WCS and WFS automatically for the data.
> > > That could also QGIS server do by default. But with the gateway
> > > interface QGIS could provide some custom services, maybe working
> > > properly only with some specific data.
> > What would be the benefit of the gateway interface class compared to
> > other services using FastCGI? E.g. if one want to build a WFS/WPS
> > service with QGIS,
> > the obvious solution would be to create qgis_wps_serv.fcgi or similar. Is
> > it
> > the idea to have shared service functionality on service level which is
> > specific to QGIS services?
> configurations.
> giovanni
> > Regards,
> > Marco
> > Am Donnerstag, 20. Oktober 2011, 22.54:30 schrieb Martin Dobias:
> > > On Thu, Oct 20, 2011 at 5:40 PM, G. Allegri <giohappy at gmail.com> wrote:
> > > > 2011/10/20 Martin Dobias <wonder.sk at gmail.com>
> > > >> On Thu, Oct 20, 2011 at 4:00 PM, G. Allegri <giohappy at gmail.com>
> > wrote:
> > > >> > I imagine a plugin system, similar to Qgis Desktop, where every
> > > >> > service is
> > > >> > discovered/registered if available in certain library paths.
> > > >> I am not sure if such implicit (automatic) registration would be
> > > >> good. Imagine that you have several web services. You would like to
> > > >> run a public WMS server and also another bunch of services for a
> > > >> limited group of users. Having all the services available in both
> > > >> instances would not be very good - e.g. with a WMS server you may
> > > >> automatically provide WPS server.
> > > > Looking at similar architectures, Geoserver seems to work this way,
> > > > leaving to a security/configuration layer to enable and control the
> > > > availability of the extensions.
> > > > Anyway, we can avoid an automatic discovering, and control their
> > exposure
> > > > through a configuration system (eg a simple configurations file).
> > > Martin
> > > _______________________________________________
> > > Qgis-developer mailing list
> > > Qgis-developer at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Dr. Marco Hugentobler
> > Sourcepole -  Linux & Open Source Solutions
> > Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
> > marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> > Technical Advisor QGIS Project Steering Committee
