[Qgis-developer] Map vs. Line line labelling orientation
Sandro Santilli strk at keybit.net
Sat Oct 22 11:51:36 EDT 2011
On Sat, Oct 22, 2011 at 12:45:33PM -0300, Martin Dobias wrote:
> the intended semantics is as follows:
> - with the "map" orientation the "above line" and others should work
> as one would expect: the label should appear above the line
What would you expect when the line is a vertical line ?
> - using "line" orientation the "above line" actually means "on the
> left side of the line" - so that in case of left-to-right line there
> is no difference to "map" orientation, in case of right-to-left line
> the meaning of above/below is reversed to "map" orientation.
> Does that make sense to you?
The "line" orientation makes sense to me.
The "map" orientation seems insufficiently defined.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
