[Qgis-developer] In the Postgis driver don't list schema without geometries
Sandro Santilli strk at keybit.net
Mon Oct 24 13:53:00 EDT 2011
On Mon, Oct 24, 2011 at 07:22:50PM +0200, aperi2007 wrote:
> Hi,
> Using the postgis driver,
> the option "Also list tables with no geometry"
> work only on shemes where there is almost a table with geometry :)
> Infact I create a scema with only one table and this single table
> has no geometry.
> This schema and the table is not lists when try to connect to the DB.
> I guess this is a bug
> but I don't know if this is a problem for my qgis:
> qgis-dev (b34f924) on windows,
> with postgres 9.1.1 and postgis 2.0
> someone can confirm it ?
I can't find b34f924 in my git clone, is this
the windows-only modification version ?
With 59be561 (on Ubuntu 10.04) it works fine.
Single table with single geometry field and no records in a schema.
Shown checking the "Also list tables with no geometry" and
hidden when unchecking it.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
