[Qgis-developer] API proposal: fetching of features
luca_manganelli at comune.trento.it luca_manganelli at comune.trento.it
Fri Oct 28 02:01:14 EDT 2011
Martin Dobias wrote on 27/10/2011 19.07.43
> What do you think? I would like to gather your opinions - is it
> good/bad/complex/inefficient/nonintuitive/verbose/...?
+1, .select() and derivates are, maybe, the most important function and
it's crucial that they must be optimized.
Using them in python is really slow on large datasets.
I would like to have this simple (and optimized) function:
    layer.selectOIDS ( extent ) -> returns an array of OIDS (integer),
fetching only one field
and then I use:
    layer.fetchAttributesByOID ( OID ) -> returns an array of attributes
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111028/ca7a8cf3/attachment.html
