[Qgis-developer] Expression based labeling
Marco Hugentobler marco.hugentobler at sourcepole.ch
Fri Oct 28 02:32:07 EDT 2011
Hi Nathan
> I agree. I can't really think of a use case where you wouldn't need it on
> always.  Looking at the code it seems that adding the direction symbol to
> the label doesn't work with multiline labels.
How is it with curved line labels, do they work with multiline?
Btw I noticed that the 'engine settings' button is always greyed out
for me recently.
Regards,
Marco
On 27.10.2011 23:58, Nathan Woodrow wrote:
> On Fri, Oct 28, 2011 at 7:38 AM, Martin Dobias <wonder.sk at gmail.com
> <mailto:wonder.sk at gmail.com>> wrote:
>     The question is whether it ever makes sense to disable multiline
>     labels. Therefore for the simplicity of the GUI I would suggest to
>     remove the option completely and always keep it on... unless there is
>     a case when multiline labels should be explicitly disabled?
> on always.  Looking at the code it seems that adding the direction
> symbol to the label doesn't work with multiline labels.
> Maybe just enable it by default for now, fix the direction symbol
> stuff, remove it....wait for someone to bring it up as a issue.
> - Nathan
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111028/7d766852/attachment-0001.html
