[Qgis-developer] Re: Module piping GUI [Was: analytical workflow]
Johan Van de Wauw johan.vandewauw at gmail.com
Thu Sep 29 07:45:52 EDT 2011
On Thu, Sep 29, 2011 at 12:51 PM, Camilo Polymeris <cpolymeris at gmail.com> wrote:
> Two main possible designs for this GUI came up:
> Either, a "connect-the-boxes"-style GUI (a graph):
>> http://www.gvsig.com/files/images/screenshots/gvSIG_Sextante_02.png
> or, a patchbay-style GUI:
>>> http://ubuntu.allmyapps.com/data/q/j/qjackctl-jack-control/UBUNTU-9.04/qjackctlPatchbayForm1.png
I understand the first one (graph) immediately.
I have no clue how the second one works with the lines across two
lists. From a usability perspective I'd choose the first one.
If the GUI interface is an issue, I think you can also generate a
similar tree structure from the DAGs :
Flow accumulation
+Watersheds
++Elevation: Raster layer1
++Channel Network
+++Elevation:...
+++Other option:...
++other input
In fact this is also the format you get in SAGA when you look to the
history of the file. I've attached a small example.
Perhaps this is what you ment with patchbay style, but I still don't
get what the lines mean, and why some properties would be on the left
or right.
Johan
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110929/db346ff1/tree-0001.png
