[Qgis-developer] SEXTANTE for QGIS has been released
Pedro Venâncio pedrongvenancio at yahoo.com
Wed Apr 11 17:53:27 EDT 2012
Hi Victor and Paolo,
Sorry but how can I add the path for SAGA on Debian?
Thank you very much!
Pedro
----- Original Message -----
>> When calling SAGA or R on linux, the path to the software is not
>> needed, since it assumes they are on PATH already. I will remove that
>> setting and the warning in case it is running on linux
> currently however it is necessary, because the paths are not found, can you
> confirm?
Sorry, I was wrong, the path is needed, because it is added then to
PATH in the batch file. The R call does not use one, since it passes
the batch process to R directly, and assumes R to be on the PATH...
