[Qgis-developer] Add a simpler default setting for a fresh installation
Andreas Neumann a.neumann at carto.net
Mon Apr 16 06:03:38 EDT 2012
 ok - I am not strongly against it. It really depends on the map scale
 and projections one is working at. I only use one projection and very
 large scales (street or community level). I usually print north arrow
 and scalebar on the print layout. On the main QGIS screen they usually
 get in my way. But I can always override the setting - so not a problem.
 Andreas
 On Mon, 16 Apr 2012 11:20:17 +0200, MORREALE Jean Roc wrote:
> In my experience, new users are quite fond of having them :
> - the north, so then they realize that their data isn't projected
> correctly
> - the graphic scale, because they can't figure a number but can
> relate to a line (and use their thumb to compare (not a joke))
> Le 16/04/2012 11:11, Andreas Neumann a écrit :
>> Hi,
>> I agree with all of your ideas, except for adding the north icon and
>> the
>> scalebar by default. The map always points north in QGIS, so why the
>> arrow? Also, the map scale is already in the status bar, so why the
>> double information?
>> All other suggestions make sense to me.
>> I would also add the following default settings:
>> Tab Map Tools:
>> - mode: Top down, stop at first hit
>> - checkbox enabled for "open object form if only a single result
>> Andreas
>> On Mon, 16 Apr 2012 11:05:01 +0200, MORREALE Jean Roc wrote:
>>> Hi,
>>> Would it be possible to change the default parameters of QGIS ? For
>>> now a new user gets all the tool bars on the first launch and most
>>> of
>>> the tools are not visible. Some such as advanced digitizing, grass,
>>> overview should be off by default. The others should be spread out,
>>> for example the navigation bar could be set on one side of the
>>> application.
>>> Somme other changes could be :
>>> - to activate the north icon and the scale bar for the canevas
>>> - to add a default 10 pixel radius for snapping tolerance and
>>> vertex edit
>>> - activate "show makers only for selected features"
>>> - switch to "zoom to mouse cursor" to have the same behavior than
>>> most of the web-mapping tools
>>> These changes would make the software less frightening, less
>>> cluttered for newcomers.
>>> Regards,
>>> MORREALE Jean-Roc
> Qgis-developer mailing list
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
