[Qgis-developer] SEXTANTE backends
Vincent Picavet vincent.ml at oslandia.com
Tue Apr 17 10:10:07 EDT 2012
+1 with everything you said !
Vincent
> Now that there is (already !) a lot of backends integrated directly into
> the core plugin, I guess there will be more and more people proposing
> improvements. I think moving to a DVCS would help, so that people can
> "pull-request" you, with all the advantages of dvcs : lower down patch
> work for you, honor contributors in the code base by preserving
> authoring, help for work on more mid/long-term feature before
> integration into your reference repository, etc...
> If my understanding is ok, the redmine instance can host a git
> repository, at the cost of two mouse clicks.
> Victor, others, what's your opinion on this ?
> About integration of the binaries, as discussed at the HF, I'm afraid
> this would be impossible to maintain. Probably even impossible to do at
> all. It makes no sense on linux where the habit is to install software
> system-wide through the package manager.
> My opinion is that it is a packager-related issue, and should not
> interfere with the plugin deployment.
> Even for windows, a package can be a bit more than just a zip to unzip.
> You'll be reimplementing osgeo4w-setup inside your plugin if you take
> that road.
> For windows, I see there is already a "qgis-grass-plugin" osgeo4w package.
> Maybe there could be a qgis-sextante-providers package, sort of virtual
> package depending on all the necessary packages for sextante backends ?
> Then, if it proves usefull and stable enough, it could even be
> integrated in the standalone qgis installer so that people downloading
> qgis out of osgeo4w also can get saga/otb/... easily ?
> Someone would need to step up to provide and maintain a saga osgeo4w
> package [1]. The rest of the current sextante backends are already
> packaged. Such "sextante" virtual package is something which is doable on
> Debian-based distros (I don't know anything about non-Debian-based
> linux...)
> Julien
> [1] http://trac.osgeo.org/osgeo4w/ticket/273
> Le 17/04/2012 13:56, Victor Olaya a écrit :
> > that is a question that should be discussed.
> > Algorihtm providers in SEXTANTE can be turned off, so I would prefer
> > to have them all together, since the size is rather small, and to
> > activate them within SEXTANTE.
> > However, there is already a mechanism for creating plugins that
> > connect their algorithms into SEXTANTE, for those who prefer to
> > develop them outside of SEXTANTE and distribute them separately as
> > well.
> > As I said, in the case of small plugins, it should not be a problem to
> > include them in SEXTANTE. The main issue I see is related to providers
> > using external apps and how to distribute them. I think that this
> > should also be discussed.
> > For now, I will keep all the backends and algorithms that I develop in
> > one single plugin along with the SEXTANTE core. If other developers
> > want their algorithms also included there, just tell me. And if
> > someone creates its own provider as an external plugin, it should be
> > clearly stated that it requires SEXTANTE, so people can install it in
> > advance and also can search for SEXTANTE-based plugins.
> Qgis-developer mailing list
