[Qgis-developer] Syntax for using QList<QgsMapLayer *> signal in python
Tim Sutton lists at linfiniti.com
Thu Apr 19 15:32:53 EDT 2012
Hi
On Thu, Apr 19, 2012 at 7:12 PM, Larry Shaffer <larrys at dakotacarto.com> wrote:
> Sorry for extending the confusion. I now understand you were referring to
> the layersAdded signal.
Thanks for the ideas - I got it working using the @pyqtslot decorator
instead of the older @pyqtsignature decorator.
Regards
Tim
> Larry
> On Thu, Apr 19, 2012 at 11:03 AM, Larry Shaffer <larrys at dakotacarto.com>
> wrote:
>> Hi Tim,
>> On Thu, Apr 19, 2012 at 3:33 AM, Tim Sutton <lists at linfiniti.com> wrote:
>>> Hi
>>> On Thu, Apr 19, 2012 at 11:28 AM, Tim Sutton <lists at linfiniti.com> wrote:
>>> > Hi
>>> > On Thu, Apr 19, 2012 at 11:14 AM, Denis Rouzaud
>>> > <denis.rouzaud at gmail.com> wrote:
>>> >> I would try
>>> >> SIGNAL("layersWillBeRemoved(QStringList)")
>>> > Oh but its not a string list that the signal is emitting but rather a
>>> > QList of pointers to map layers?
>>> Oh sorry I see I was the source of confusion with my python snippet -
>>> yes it is the added slot I am interested in.
>> I noticed that signal is already defined in the API:
>> void QgsMapLayerRegistry::layersWillBeRemoved (QStringList  theLayerIds)
>> Are you replacing or overloading it?
>> If you're overloading it, could PyQt be getting confused by seeing both
>> signals as returning a list?
>>> >> On 04/19/2012 11:09 AM, Tim Sutton wrote:
>>> >> Hi All
>>> >> Does anyone know the appropriate way to connect to the new
>>> >> QgsMapLayerRegistry signal I added in python:
>>> >> void layersAdded( QList<QgsMapLayer *> theMapLayers );
>>> >> I tried:
>>> >>             QtCore.QObject.connect(QgsMapLayerRegistry.instance(),
>>> >> QtCore.SIGNAL('layersWillBeRemoved(QList<QgsMapLayer*>)'),
>>> >>                     self.getLayers)
>>> >> But that doesnt seem to be hitting my slot.
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
