[Qgis-developer] SpatialIndex error on qgis-server compiling
Etienne Tourigny etourigny.dev at gmail.com
Fri Apr 27 16:40:51 EDT 2012
Andrea -
First, why don't you follow the previous suggestions and install
libspatialindex-dev ?
Second, that link seems way outdated, you should check out
http://libspatialindex.github.com/ - if you really want to build it!
Etienne
On Fri, Apr 27, 2012 at 5:30 PM, Andrea Peri <aperi2007 at gmail.com> wrote:
> Thx both,
> I was not understand the spatialindex was added just now.
> To add it I will like try to compile the spatialindex from source.
> So I download it from this link:
> http://sourceforge.net/projects/spatialindexlib/support
> To compile it , seem is need also the Tools Library,
> but it seem not available.
> Is the sources of tools library available
> somewhere ?
> Thx,
> 2012/4/27 G. Allegri <giohappy at gmail.com>
>> You need to install libspatialindex.
>> (On Debian/Ubuntu >apt-get install libspatialindex-dev)
>> or set SPATIALINDEX_INCLUDE_DIR and SPATIALINDEX_LIBRARY to the right
>> path.
>> giohappy
>> 2012/4/27 Andrea Peri <aperi2007 at gmail.com>
>>> Hi,
>>> today I update my qgis-server from trunk,
>>> but in the cmake phase I see an error:
>>> > CMake Error: The following variables are used in this project, but they
>>> > are
>>> > set to NOTFOUND.
>>> > Please set them or make sure they are set and tested correctly in the
>>> > CMake
>>> > files:
>>> >    used as include directory in directory
>>> > /home/archivio/tomcat/software/qgis/Quantum-GIS/src/core
>>> >     linked by target "qgis_core" in directory
>>> I use
>>> with_desktop = off
>>> with_mapserver = on
>>> with_binding = off.
>>> Any hints ?
>>> Thx,
>>> Andrea Peri
>>> qwerty àèìòù
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Andrea Peri
> qwerty àèìòù
