[Qgis-developer] pdf or latexpdf?
Paolo Cavallini cavallini at faunalia.it
Sat Apr 28 01:19:27 EDT 2012
Il 27/04/2012 10:27, Paolo Corti ha scritto:
> Hi Paolo
> no one still decided, at least me, if to go with latexpdf or pdf (that
> is using rst2pdf).
latexpdf seems more picky, and the results seem cleaner to me.
> In any case, regarding your error: do you have in your system PIL? [1]
Do not know, I didn't find a package with a similar name. However, other
sources build fine.
> For me the pdf build for user_guide is working well, instead with
> latexpdf I have errors, and the process fails.
> Will give a look into this later, now I am consolidating the directory
> structure for images, in order to have the possibility to have image
> internationalization as well
> ciao
> p
> [1] http://pypi.python.org/pypi/PIL/1.1.6
All the best.
Paolo Cavallini
See: http://www.faunalia.it/pc
