[Qgis-developer] Building QGIS in Mac OS X (Mountain Lion i.e. 10.8) with QtSQL support
Noli Sicad nsicad at gmail.com
Fri Aug 3 16:19:43 PDT 2012
Regarding, qmake, etc. in Mac OS X system.
Any suggestion how to make this thing working based on this post below?
http://osgeo-org.1560.n6.nabble.com/building-qgis-on-centos-td4100055.html
Noli
On 8/4/12, Noli Sicad <nsicad at gmail.com> wrote:
> How can I incorporate qmake in my system?
> It seems that I can't use qmake in my terminal right now.
> See this logs.
> Last login: Sat Aug  4 08:56:51 on ttys004
> Nolis-MacBook-Pro:bin nsicad$ qmake --help
> -bash: qmake: command not found
> Nolis-MacBook-Pro:bin nsicad$ ls
> Designer.app		moc			qt3to4
> Linguist.app		pixeltool.app		qttracereplay.app
> QMLViewer.app		qcollectiongenerator	rcc
> lconvert		qdoc3			uic
> lrelease		qhelpconverter.app	uic3
> lupdate			qhelpgenerator		xmlpatterns
> macdeployqt		qmake			xmlpatternsvalidator
> Nolis-MacBook-Pro:bin nsicad$ qmake -help
> Double clicking qmake works.
> Noli
>> It is stlll not clear to me what to do with QtSDK (i.e. Qt 4.7.4) and
>> XCode 4.x with Command Line Tool for compiling QGIS in Mac OS X.
>> Tim has this wiki - Building QGIS 0.8 with Qt4.x for Ubuntu.
>> https://help.ubuntu.com/community/BuildingQuantumGisPoint8FromSource
>> Can some lighten me how to use QtSDK 4.7.4 for Building QGIS in Mac OS X?
>> Noli
>> On 8/3/12, William Kyngesburye <woklist at kyngchaos.com> wrote:
>>> As it says, "when using a system SDK".  If you just compile for your
>>> current
>>> system, with no SDK options, you don't need to do this.
>>> I suppose this should be removed, since I was aiming for simple current
>>> system builds in the instructions.
>>> On Aug 2, 2012, at 11:44 PM, Noli Sicad wrote:
>>>> My QtSDK for Mac OS X is installed in:
>>>> /Users/nsicad/QtSDK/Desktop/Qt/474/gcc/
>>>> See screenshot attached.
>>>> What i am going to do inorder that qt library, include, etc  can be
>>>> founded during compilation?
>>>> This is copied (below) from Building QGIS for Mac OS ...
>>>> Leopard note: Qt includes a couple non-framework libraries in /usr/lib.
>>>> When using a system SDK these libraries will not be found. To fix this
>>>> problem,
>>>> add symlinks to /usr/local:
>>>>  sudo ln -s /usr/lib/libQtUiTools.a /usr/local/lib/
>>>>  sudo ln -s /usr/lib/libQtCLucene.dylib /usr/local/lib/
>>>> These should then be found automatically. Earlier systems
>>>> may need some help by adding '-L/usr/local/lib' to
>>>> CMAKE_SHARED_LINKER_FLAGS,
>>>> CMAKE_MODULE_LINKER_FLAGS and CMAKE_EXE_LINKER_FLAGS in the cmake
>>>> build.
>>>> From the above statements what I am going to do with my QtSDK
>>>> installation? What need to copy to /usr/lib or link?
>>>> Thanks.
>>>> Noli
>>>> <Screen Shot 2012-08-03 at 2.23.31 PM.png>
>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>> http://www.kyngchaos.com/
>>> "Mon Dieu! but they are all alike.  Cheating, murdering, lying,
>>> fighting,
>>> and all for things that the beasts of the jungle would not deign to
>>> possess
>>> - money to purchase the effeminate pleasures of weaklings.  And yet
>>> withal
>>> bound down by silly customs that make them slaves to their unhappy lot
>>> while
>>> firm in the belief that they be the lords of creation enjoying the only
>>> real
>>> pleasures of existence....
>>> - the wisdom of Tarzan
