[Qgis-developer] Building QGIS in Mac OS X (Mountain Lion i.e. 10.8) with QtSQL support
Noli Sicad nsicad at gmail.com
Fri Aug 3 22:05:26 PDT 2012
SIP in not building Mountain Lion.
I use homebrew as well, same problem.
Nolis-MacBook-Pro:bin nsicad$ brew install sip
==> Downloading http://www.riverbankcomputing.co.uk/hg/sip/archive/4.13.3.tar.gz
######################################################################## 100.0%
==> Patching
patching file build.py
Hunk #1 succeeded at 185 (offset 6 lines).
Hunk #2 succeeded at 198 (offset 6 lines).
patching file siputils.py
Hunk #1 succeeded at 1485 (offset 51 lines).
==> python build.py prepare
==> python configure.py --destdir=/usr/local/Cellar/sip/4.13.3/lib/python2.7/sit
==> make install
cc -c -Os -w -pipe -march=native -Qunused-arguments
-mmacosx-version-min=10.8 -Os -w -DNDEBUG -I. -o main.o main.c
-mmacosx-version-min=10.8 -Os -w -DNDEBUG -I. -o transform.o
transform.c
-mmacosx-version-min=10.8 -Os -w -DNDEBUG -I. -o gencode.o gencode.c
-mmacosx-version-min=10.8 -Os -w -DNDEBUG -I. -o extracts.o extracts.c
-mmacosx-version-min=10.8 -Os -w -DNDEBUG -I. -o export.o export.c
-mmacosx-version-min=10.8 -Os -w -DNDEBUG -I. -o heap.o heap.c
-mmacosx-version-min=10.8 -Os -w -DNDEBUG -I. -o parser.o parser.c
-mmacosx-version-min=10.8 -Os -w -DNDEBUG -I. -o lexer.o lexer.c
c++ -L/usr/local/lib -o sip main.o transform.o gencode.o extracts.o
export.o heap.o parser.o lexer.o
make[1]: c++: No such file or directory
make[1]: *** [sip] Error 1
make: *** [install] Error 2
==> Build Environment
CPU: 8-core 64-bit dunno
OS X: 10.8-x86_64
Xcode: 4.5 => /Applications/Xcode45-DP2.app/Contents/Developer
X11: 2.7.2 @ /opt/X11
CC: /usr/bin/clang
CXX: /Applications/Xcode45-DP2.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++
=> /Applications/Xcode45-DP2.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang
LD: /usr/bin/clang
CFLAGS: -Os -w -pipe -march=native -Qunused-arguments -mmacosx-version-min=10.8
CXXFLAGS: -Os -w -pipe -march=native -Qunused-arguments
CPPFLAGS: -isystem /usr/local/include
LDFLAGS: -L/usr/local/lib
MACOSX_DEPLOYMENT_TARGET: 10.8
MAKEFLAGS: -j8
Error: Failed executing: make install (sip.rb:41)
These existing issues may help you:
    https://github.com/mxcl/homebrew/issues/12388
    https://github.com/mxcl/homebrew/issues/12491
Otherwise, this may help you fix or report the issue:
    https://github.com/mxcl/homebrew/wiki/bug-fixing-checklist
On 8/4/12, Noli Sicad <nsicad at gmail.com> wrote:
> Any suggestion of the better SIP and PyQt version that works with QGIS?
> Which SIP and PyQt version that works with QGIS?
> Noli
> On 8/4/12, William Kyngesburye <woklist at kyngchaos.com> wrote:
>> That's a problem to ask on the PyQt list.
>> On Aug 3, 2012, at 10:45 PM, Noli Sicad wrote:
>>> Cmake no problem now.
>>> Nolis-MacBook-Pro:~ nsicad$ which cmake
>>> /usr/local/bin/cmake
>>> Now, I got problem compiling SIP.
>>> Last login: Sat Aug  4 13:35:51 on ttys005
>>> Nolis-MacBook-Pro:sip-4.13.4-snapshot-5775580258b3 nsicad$ python2.7
>>> configure.py -d /Library/Python/2.7/site-packages -b /usr/local/bin -e
>>> /usr/local/include -v /usr/local/share/sip
>>> This is SIP 4.13.4-snapshot-5775580258b3 for Python 2.7.2 on darwin.
>>> The SIP code generator will be installed in /usr/local/bin.
>>> The sip module will be installed in /Library/Python/2.7/site-packages.
>>> The sip.h header file will be installed in /usr/local/include.
>>> The default directory to install .sip files in is /usr/local/share/sip.
>>> The platform/compiler configuration is macx-g++.
>>> Creating siplib/sip.h...
>>> Creating siplib/siplib.c...
>>> Creating siplib/siplib.sbf...
>>> Creating sipconfig.py...
>>> Creating top level Makefile...
>>> Creating sip code generator Makefile...
>>> Creating sip module Makefile...
>>> Nolis-MacBook-Pro:sip-4.13.4-snapshot-5775580258b3 nsicad$ make
>>> make[1]: Nothing to be done for `all'.
>>> cc -c -pipe -fPIC -Os -w -DNDEBUG -I.
>>> -I/System/Library/Frameworks/Python.framework/Versions/2.7/include/python2.7
>>> -o siplib.o siplib.c
>>> -o apiversions.o apiversions.c
>>> -o descriptors.o descriptors.c
>>> -o qtlib.o qtlib.c
>>> -o threads.o threads.c
>>> -o objmap.o objmap.c
>>> -o voidptr.o voidptr.c
>>> c++ -c -pipe -fPIC -Os -w -DNDEBUG -I.
>>> -o bool.o bool.cpp
>>> make[1]: *** [bool.o] Error 1
>>> make: *** [all] Error 2
>>> Noli
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "Those people who most want to rule people are, ipso-facto, those least
>> suited to do it."
>> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
