[Qgis-developer] Building QGIS in Mac OS X (Mountain Lion i.e. 10.8) with QtSQL support
William Kyngesburye
woklist at kyngchaos.com
Sun Aug 5 07:45:41 PDT 2012
You configured Qt to compile static libraries!? Your PyQt and QGIS binaries are going to be HUGE. There are many separate binary components and much of the static Qt libraries will be redunandantly linked in to each one. Even the Qt plugins will be large.
You should really recompile Qt as OS X frameworks. If static libraries is the reason you compiled your own Qt from source, then you might as well install the prepackaged Qt binaries from Nokia and save yourself some grief trying to figure out all the changes needed in the QGIS install instructions.
On Aug 4, 2012, at 11:45 PM, Noli Sicad wrote:
> python2.7 configure.py -d /Library/Python/2.7/site-packages -b /usr/local/bin
> Nolis-MacBook-Pro:PyQt-mac-gpl-4.9.4 nsicad$ python2.7 configure.py -d
> Determining the layout of your Qt installation...
> Error: Qt has been built as static libraries so either the -g or -k argument
> should be used.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Theory of the Universe
There is a theory which states that if ever anyone discovers exactly what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarrely inexplicable. There is another theory which states that this has already happened.
-Hitchhiker's Guide to the Galaxy 2nd season intro
