[Qgis-developer] What path for QTWebKit
Marco Lechner - FOSSGIS e.V. marco.lechner at fossgis.de
Wed Aug 15 02:32:12 PDT 2012
Hi Andrea,
did you install only qtwebkit or also the -dev packages needed for
compiling (don't know about RedHat, but at Ubuntu/Debian they are
called libqtwebkit-dev or included in libqt4-dev)
Marco
Am Mi 15 Aug 2012 11:18:31 CEST schrieb Andrea Peri:
> Hi Marco,
> thx greatly for hint.
> Unfortunately my problem is opposite to your.
> I'm having a QTWEBKIT NOT found on configuring phase.
> So the cmake don't generate the files need for compilation.
> I guess the cmake search the qwebkit on a different path from where it
> is installed.
> I think to have a qtwebkit installed on a 4.6 version.
> Or perhaps is missing some sub-module of qtwebkit.
> I don't know.
> Andrea.
> 2012/8/15 Marco Lechner - FOSSGIS e.V. <marco.lechner at fossgis.de
> <mailto:marco.lechner at fossgis.de>>
>     Hi Andrea,
>     I had a similar problem two days ago, because I tried to compile
>     QGIS "WITH_DESKTOP NO" (just needed QGIS mapserver and Python
>     Bindings). ccmake was succesfull but build failed. may be this
>     info is helpful. jef should have fixed this issue in master (did
>     not try if his fix works)
>     Marco
>     Am 15.08.2012 10:26, schrieb Andrea Peri:
>>     Hi,
>>     I'm try-ing to install the QTWebKit on my RedHat.
>>     But the cmake of qgis still report me it is unavailable.
>>     Perhaps there is a different folder path.
>>     Any hint on where is searched for the QTWebKit and how it is
>>     possible to change se searched path on cmake ?
>>     Thx,
>>     Andrea Peri
>>     qwerty àèìòù
>>     _______________________________________________
>>     Qgis-developer mailing list
>>     Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Andrea Peri
> qwerty àèìòù
