[Qgis-developer] Its Test Friday!
Larry Shaffer larrys at dakotacarto.com
Fri Aug 17 15:53:39 PDT 2012
On Fri, Aug 17, 2012 at 11:23 AM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi
> On Fri, Aug 17, 2012 at 5:47 PM, Salvatore Larosa <lrssvtml at gmail.com> wrote:
>> Hi Tim,
>> 2012/8/17 Tim Sutton <lists at linfiniti.com>
>>> Title says it all really :-) How about adding one teeeny tiny python
>>> test and make the world a better place :-) Pull requests with tests
>>> will be gratefully accepted. If you are terminally lazy you can even
>>> copy and paste code from Martin's QGIS python cookbook into your test
Well, I didn't really write any tests today. However, I did work on a
couple of problems when running tests on Mac [0]. Now all the tests
appear to be working as expected (regardless of whether they pass or
fail), except the PyQGIS ones.
This fixed a failure for any call to qgscoordinatereferencesystem.cpp
that used the srs.db, which couldn't be found. I wonder why those
didn't show as a failed test?
I have one remaining test issue on Mac. I was able to override
QGIS_DATA_SUBDIR for the CMake tests (see tests/CMakeLists.txt edit),
but couldn't find a way to do it for the PyQGIS tests.
How can QGIS_DATA_SUBDIR be overridden for PyQGIS tests? I tried
putting the code that works for CMake tests in the following files, to
no avail:
tests/src/python/CMakeLists.txt
cmake/UsePythonTest.cmake
[0] https://github.com/qgis/Quantum-GIS/commit/07e3c16c634866eb8186cc156f74771cf057fe86
Regards,
Larry
>> I just sent a pull request by adding some simple test for
>> MultiGeometries[1]!
>> I hope to do something other more for test Friday!
> Thanks Salvatore, great work! Our tests graph is showing a nice
> upwards trend[1]!
> [1] http://jenkins.linfiniti.com/job/QGIS/test/?width=800&height=600
> Regards
> Tim
>> Cheers,
>> -SL
>> [1] - https://github.com/qgis/Quantum-GIS/pull/203
>>> Regards
>>> Tim
>>> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
>>> Please do not email me off-list with technical
>>> support questions. Using the lists will gain
>>> more exposure for your issues and the knowledge
>>> surrounding your issue will be shared with all.
>>> Visit http://linfiniti.com to find out about:
>>>  * QGIS programming and support services
>>>  * Mapserver and PostGIS based hosting plans
>>>  * FOSS Consulting Services
>>> Skype: timlinux
>>> Irc: timlinux on #qgis at freenode.net
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Salvatore Larosa
>> linkedIn: http://linkedin.com/in/larosasalvatore
>> twitter: @lrssvt
>> skype: s.larosa
>> IRC: lrssvt on freenode
> Skype: timlinux
