[Qgis-developer] Sextante - OTB plugin and SAR data in Mac OS X
Noli Sicad nsicad at gmail.com
Mon Aug 27 20:26:32 PDT 2012
Hi William,
Thanks for looking into this problem.
Hopefully you can make it easier for us (mac users) to have OTB and
QGIS OTB plugin working in OS X.
I think mac os users need a Remote Sensing tools e.g. OTB and QGIS OTB
python plugin.
Thanks.
Noli
On 8/28/12, William Kyngesburye <woklist at kyngchaos.com> wrote:
> Noli,
> I started looking at this to see what needs to be done to use my
> frameworks.
> First, FLTK.
> You need the dev 1.3.x source, for updates to support the new libpng in my
> UnixImageIO framework.  You also need my FreeType framework (not part of the
> QGIS requirements).
> This configuration is just minimal - no tests/examples.  I'm not sure if
> some of the options are needed for a static build, though may be if you want
> the examples.  (the build system is messy - checking for things twice,
> ignoring what I give it, ...)  in a Terminal, in the fltk source folder:
> mkdir build-snow
> cd build-snow
> cmake -Wno-dev -D CMAKE_INSTALL_PREFIX=/usr/local \
> -D CMAKE_BUILD_TYPE=MinSizeRel \
> -D CMAKE_OSX_ARCHITECTURES="x86_64" \
> -D OPTION_BUILD_EXAMPLES=OFF \
> -D HAVE_FREETYPE_H=/Library/Frameworks/FreeType.framework/Headers/freetype.h
> -D FREETYPE_PATH=/Library/Frameworks/FreeType.framework/Headers/config \
> -D LIB_png=/Library/Frameworks/UnixImageIO.framework \
> I'm working on OTB now.  I'll get back to you when I figure that out,
> probably in a day or two.
> On Aug 27, 2012, at 8:57 PM, Noli Sicad wrote:
>> Hi Julien,
>> As you can see I am not using MacPort. MacPort download the source in
>> the script that you mentioned in your previous posting?
>> http://www.orfeo-toolbox.org/otb/download.html
>> Based on the instruction above. It is not clear what to do with hg
>> cloning in Mac OS X.
>> Yes, I can do (below) in the terminal.
>> hg clone http://hg.orfeo-toolbox.org/OTB
>> Would this suffice, or I need to more?
>> What do, I do next, do I need to clone OTB-Applications and
>> OTB-Qgis-plugin?
>>    OTB-Applications
>> The current development version is available from the OTB-Applications
>> mercurial repository at: http://hg.orfeo-toolbox.org/OTB-Applications
>>    OTB-Qgis-plugins
>> The current development version is available from the OTB-Qgis-plugins
>> mercurial repository at: http://hg.orfeo-toolbox.org/OTB-Qgis-plugins
>> Noli
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Oh, look, I seem to have fallen down a deep, dark hole.  Now what does that
> remind me of?  Ah, yes - life."
> - Marvin
