[Qgis-developer] qt problem with JPEG on Ubuntu 12.04
Andreas Neumann a.neumann at carto.net
Wed Dec 26 04:24:50 PST 2012
 Hi again,
 Here is what I got as output from gdb:
 Program received signal SIGSEGV, Segmentation fault.
 0x00007ffff6393b7c in jpeg_CreateDecompress (cinfo=0xba4768,
 version=80, structsize=656) at libjpeg/jdapimin.c:37
 37          ERREXIT2(cinfo, JERR_BAD_LIB_VERSION, JPEG_LIB_VERSION,
 version);
 so it seems there is a bad JPEG library used by QGIS server?
 Any ideas what is wrong with my system?
 Thanks,
 Andreas
 On Tue, 25 Dec 2012 13:32:07 +0100, Marco Hugentobler wrote:
> Hi Andreas
> I'm using 12.04 as well and it works for me with qgis_mapserv.fcgi
> linked against libjpeg.so.8
> Could you check, if you have Qt's jpeg plugin installed
> (/usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqjpeg.so) ? It
> is contained in the package libqtgui4 and linked against libjpeg.so.8
> too.
> Regards,
> Marco
> On 25.12.2012 12:54, Andreas Neumann wrote:
>> Hi,
>> I upgraded my server from Ubuntu 10.04 LTS to 12.04 LTS. I
>> recompiled QGIS server with the new qt and JPEG libraries and the
>> compile and install went fine. However, since the upgrade, QGIS server
>> cannot read and write JPEG files anymore. QGIS server crashes whenever
>> the source (WMS) or the output involves a JPEG read or write. This is
>> regardless of the input raster source (could be TIFF or WMS). PNG and
>> PNG8bit output seems to work fine.
>> I googled for qt and JPEG problems, but could not find much that
>> sounded similar to my problem.
>> Using ldd I saw that qgis_mapserv.fcgi is linked against
>> libjpeg.so.8 - is this a problem? Should it be linked against
>> libjpeg.so.62?
>> Thank you if you have any idea about my problem.
>> Andreas
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
